Fox DHX Air - what ...
[Closed] Fox DHX Air - what size bushings?
[#1244320]
Hi,
what size bushings do i need for my fox dhx air 5.0? cant seem to find the info anywhere. are all fox bushings standard size?
Posted : 21/01/2010 10:24 am
BETD say they are all 1/2", perhaps you can help with my query on a seperate post will 1/2" refer to the spacing in the frame? Are all shock bushes the same diameter?
Posted : 21/01/2010 12:26 pm
Fox take 1/2"- the bush is press fitted into the shock eyelet. They are usually nylon, or occasionally metal.
The reducers (metal spacers) which sit either side of the shock to space it between your frame are specific lengths for your frame.
For more info, see [url= http://www.tftunedshox.com/info/mount_kits_bushings.aspx ]TFtuned[/url]
Posted : 21/01/2010 12:30 pm
Thanks Rock !
Posted : 21/01/2010 2:29 pm
