Help please threadi...
[Closed] Help please threading gone in sunline stem
[#3110692]
After a crash on my new bike today I noticed my threading in one of the top bolts of my sunline stem started to shred bits of metal after a closer look at looks like it's lost it's Thred and won't tighten am I screwed and need to buy another stem or is there a hope
Posted : 03/09/2011 6:46 pm
get a new one IMO. Stems are not something you want to fail.
You could drill and helicoil or retap with a larger bolt but it all depends on how chunky the stem is. If it's an XC-1 then forget it. You can pick up the same stem body from On One and superstar for a lot less.
Posted : 03/09/2011 6:49 pm
Helicoiling will fix it. Any decent engineering workshop will do it for you. It will be just as strong as before.
Posted : 03/09/2011 7:06 pm
really depends how much meat there is to drill into to fit the helicoil.
Posted : 03/09/2011 7:07 pm
Thanks guys
Posted : 03/09/2011 8:39 pm
what stem is it?
Posted : 03/09/2011 9:10 pm
Drill it out and put a longer bolt through it with a nut on the end. (if you a bit tight for cash) if not just buy one from you Lbs
Posted : 03/09/2011 9:29 pm
 jedi
it happened to 2 sunline stems when i over tightended them during my creaky ck headset period. i got the ali slotted to take a nyloc nut/bolt= winner
Posted : 03/09/2011 10:12 pm
It's a sunline v one stem thing I've over screwed the bolt
Posted : 03/09/2011 11:02 pm
