Hollowtech II BB Cu...
[Closed] Hollowtech II BB Cups - Where to buy?
[#839773]
I need a replacement BB for my HT II BB.
Where is the CHEAPEST place o buy one.
Yes I know I'm tight.
Posted : 04/09/2009 5:51 pm
Replacing the bearings yourself is probably the cheapest option...
Posted : 04/09/2009 6:18 pm
greasy, what jam bo said. Have a look at previous threads, a set of bearings is £4.50 off ebay and its pretty straightforward to remove the old ones and replace em. Certainly if youre tight its the only way.
http://www.singletrackworld.com/forum/topic/rip-shimano-xt-ht2-bottom-bracket-long-live
cut and paste my post from there...
2 new bearings less than a fiver from ebay. About 15 minutes to fit. Search "what external BB" in forum search, a load of us are doing it, and "how to" and ebay links were posted along with positive results.
http://www.fettling.co.uk/aspbite/articles/articles.asp?intArticlesID=47
you knock the bearings out in the same manner. then you want 2 of these
http://cgi.ebay.co.uk/6805-2RS-61805-2RS-RUBBER-SEALED-BEARING-25x37x7mm_W0QQitemZ310125448454QQcmdZViewItemQQptZUK_sportsleisure_cycling_bikeparts_SR?hash=item4834eacd06&_trksid=p3286.c0.m14
£4.50 vs £25. I know which I prefer.
Posted : 04/09/2009 6:24 pm
Thanks guys. As it happens the bearings are fine - I re-greased them recently. However I believe the noise that is coming from my BB may be because one of the dust covers is falling apart. Don't s'pose you can buy then separately.
Posted : 04/09/2009 8:55 pm
