Hope Post mount to ...
[Closed] Hope Post mount to IS fork adapter - sanity check please
[#400908]
I'm changing forks from manitou post to rockshox IS mount.
Got 160mm mini mono caliper (6 years old) at the moment (post mounted). To fit to new forks I'll need an adapter. I'm going to take the opportunity to step up from a 160 disc to a 180.
Is this the right adapter
74mm Post to IS 183mm
http://www.chainreactioncycles.com/Models.aspx?ModelID=15622
They sell 180 & 183mm rotors! So will I need a 183mm rotor?
http://www.chainreactioncycles.com/Models.aspx?ModelID=3486
Just could do with a sanity check as having a bad day so far.
Thanks for reading.
Posted : 17/03/2009 10:38 pm
Looks like the correct mount, use the 183mm rotor for an ideal match.
Posted : 17/03/2009 10:47 pm
weird how they do 180 & 183mm eh? why change?
Posted : 17/03/2009 10:49 pm
just looked wiggle do a 185mm!
Posted : 17/03/2009 10:51 pm
one type, 180mm is for IS mount, 183mm is for post mount.If you're hell bent on a 180mm then you can fiddle it with other Hope mounts(160mm rear).
Posted : 17/03/2009 11:04 pm
Did Hope do post mount calipers 6 years ago?
Posted : 17/03/2009 11:27 pm
They even did the C2 in a post mount, so I guess so.
Posted : 18/03/2009 12:04 am
Ah, I thought Mono minis were all IS mount until relatively recently.
Posted : 18/03/2009 9:37 pm
right, its simple really.
hope used to do mono minis in 160/180/200, when they canged to the newer versions they changed to 160/183/203 to match other companies 160/203 format.
If you want to run a 180 on the front (becasue youve got a rotor already say) then you could use [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=13738 ]this[/url]. Yes i know it says 160 but a 160 rear adaptor fits a 180 when bolted to a fork (the mounts on a fork are a different distance from the axle than frame mounts)
Posted : 18/03/2009 9:47 pm
I use Shimano adaptors for Hope brakes and hope ones for Shimano. When I tried H-H and S-S it wasn't working properly. Have fun!
Posted : 18/03/2009 10:10 pm
