Hope pro 2 10mm con...
[Closed] Hope pro 2 10mm conversion
[#1779330]
Has anyone done the 10mm conversion themselves? Should I try it without any specialist tools or get a shop to do it for me?
How much will a shop charge roughly?
I got the 10mm bolt through rear kit from CRC and a Superstar 10mm axle.
Posted : 07/07/2010 10:42 pm
it's very easy, and afterwards when your freehub won't turn it is because you have forgotten to put the spacer back in
search on the hope site, there's a teardown video which should help. You just follow that and pop the new axle in.
Posted : 07/07/2010 10:49 pm
they use drifts and other things im not aware of or own...
Posted : 07/07/2010 10:51 pm
well if you're worried, there's a set of drifts and everything you need available.
i think it's this here: http://shop.18bikes.co.uk/products.php?plid=m12b0s406p661
I made do with what I had available
Posted : 07/07/2010 10:53 pm
