Hope XC Front Hub -...
[Closed] Hope XC Front Hub - Servicing ?
[#1257390]
I am a mechanical numpty so could do with some help please.
My faithful 8 year old XC front hub has developed some alarming play. Can anyone point me at a guide, preferably with pics on how to service it ?
Cheers all.
Posted : 25/01/2010 12:34 pm
I think there is one on the Hope site.. 8 years isnt a bad run is it. 🙂
Posted : 25/01/2010 12:40 pm
I'm lucky to get 8 [b]months[/b] from my bearings 🙂
Posted : 25/01/2010 12:44 pm
Dave I wlll do it for you I will get the bearings from Merlin - it will take at most 5 mins assuming we can drift out your bearings easily.
E-mailed you instructions - it is easy and you get to use a hammer!!!
Posted : 25/01/2010 12:48 pm
[i]it will take at most 5 mins assuming we can drift out your bearings easily.[/i]
Ho Ho, good luck with that then....
Posted : 25/01/2010 2:02 pm
[url= http://www.hopetech.com/technical/tech_XC_FRONT.htm ]Ok Found this.[/url]
Looks pretty straight forward. Just how medieval can I get on the axle ?
Posted : 25/01/2010 2:05 pm
 wors
let me know when you do it, i'll pop round and have a laugh
Posted : 25/01/2010 2:07 pm
I've serviced my front hub about 5 times using a lump hammer with no insideous problems.
Posted : 25/01/2010 2:08 pm
marvel at how strongly the O ring in the cap can grip the axle, and how far a small biro spring can shoot a freewheel pawl! Spanish Inquisistion level.
Posted : 25/01/2010 2:10 pm
place a bolt in the end of the axle to protect it when drifting it out, it stops you mushrooming the axle end.
Posted : 25/01/2010 3:31 pm
nickc - Member
Shall I you tube it Kaesae style?
Seriously hit the axle one side pops out the bearing as axle comes out on other side.put it back in hit the other side and it pops the other side bearing out. drift the bearing out- easy as you just took it out anyway. Insert one bearing with suitable drift - socket for example insert axle from other side inset remaining bearing - like i said 5 mins
Posted : 25/01/2010 3:46 pm
