Knackered Avid Pads
[Closed] Knackered Avid Pads
[#399736]
Wasn't gonna bother posting this, but then thought it was worth it to try and keep things balanced on here.
Previous brakes were Magura Julies. I had several sets of original pads on them - no problems. I then put 5 pairs of Superstar pads on them - no problems either. Comparable wear/performance for less money. Excellent.
New brakes are Avid J7's. A few weeks ago during a ride my rear brake seemed to have increased lever travel and reduced braking performance in a very short space of time.
I ordered some new pads (Superstar) as I had noticed the rear pads had been getting a bit low for a while and assumed they had given up the ghost. But, when I went to change them the other day, one pad had gone completely and I had been braking on the backing plate, whereas the other pad still has a fair amount of pad on it. Whenever I have checked the pads up to this point they always seemed to be wearing evenly and the fronts are wearing evenly too, so I can only assume that the pad material fell off the backing of this particular pad, which would explain the fast drop off in performance.
Seems a bit crap as they are original Avid pads. But, not overly bothered as the brake still worked with 1 pad & 1 backing plate.
Just wanted to bring it up, as lots of people are only too willing to slag off Superstar pads, but so far I have had 100% reliable performance from them and not from OEM pads.
That's all. Feel free to stop yawning now.
Posted : 17/03/2009 4:21 pm
Posted : 17/03/2009 4:34 pm
never had this happen with Avid pads, have had issues with OEM pads and now only use Avid genuine - probably you will always have the odd bad pad, it's a stressed part, suffers temp changes, dirt etc and sometimes you'll have a failure..
Posted : 17/03/2009 4:47 pm
Count, agreed. Just thought I would bring it up to try and balance the view that Superstar pads = crap, original manufacturer pads = good.
I am sure there are 100,000's of pads out there. Some will fail & some won't. Even when this pad did seem to give up the ghost, rear braking was still acceptable with one good pad.
Posted : 17/03/2009 4:52 pm
