Magura FR disk brak...
[Closed] Magura FR disk brakes. Different caliper sizes?
[#1388822]
Hi
Are the mounts of front and rear calipers of the older 05ish calipers different sizes?
Presumably they are as mine were 185 front rotor , 160 rear rotor as std. Odd though because yes they look the same.
Posted : 07/03/2010 10:01 am
rear is mounts fit a 20mm smaller rotor than the front ones (so my avid BBs, using the same adaptors, fit F/R 200/180 or 180/160)
(200 vs 203 or even 205 seems to be "identical" - with my brakes I sometimes just have to shim up a tiny bit with washers under the caliper)
my bet is that your calipers are identical (but I've never looked at a magura brake)
Posted : 07/03/2010 10:19 am
scardypants is spot on
the front is IS mount but is 180mm (not the std 160) the rear is std 160mm
Posted : 07/03/2010 12:17 pm
thanks. it just seems that the a2z 205 adapter's give slightly different horizontal spacings from front to rear. Thought I may have put the cailpers on incorrectly as i've re-bled them after adding new hoses.
cheers
Posted : 07/03/2010 1:37 pm
I think the 205 adapter will make it 225mm as the front is already off set for a 180mm rotor. If it's the front you are on about
Posted : 07/03/2010 3:23 pm
yep. just a couple of mm difference.
Posted : 07/03/2010 3:57 pm
