Pike service - not ...
[Closed] Pike service - not getting full travel
[#1824954]
I recently serviced my coil Pikes (454s, 2007 I think) which went well (I thought) and initially they were plush and fine. But since then the forks will eventually run out of travel around the 95mm mark on the stantions.
It's not a mechanical lockout but I suspect that it's oil related. I put 120ml of 5wt in the non-coil upper (which I'm fairly sure is the correct amount) and 15ml of 15wt in each lower.
My thinking now is that either some of the oil from the lower leg (15ml of 15wt) is getting up into the damper section OR some of the 120ml of 5wt is leaking into lower leg. This causes the fork to lockout and not achieve full travle.
Any suggestions or links would be very handy. I don't really want to send them away as it's not my style but I suspect something is up with them internally, as I've followed the instructions to the letter.
Posted : 23/07/2010 10:27 am
ps this is all with the lockout switched off!
Posted : 23/07/2010 10:29 am
Think you only have to put in 15ml in lowers - never heard of putting more in the upper section.
Service vid here - same as Boxxers:
http://dirt.mpora.com/news/how-to-maintain-your-boxxer-forks.html
Posted : 23/07/2010 10:32 am
 LoCo
Did you change all the seals? It is either too much oil in the damper/Moco side. Either not all drained out when serviced or the seal between the damper and lower leg oil chambers is leaking as you said.
edit: and 120ml is correct in the damper upper leg.
Posted : 23/07/2010 10:33 am
Sorry, just decoded this - a common fault with Pikes is the damping cartridge leaks into the lower chamber and reduces travel - sounds like the problem you described.
Ignore my non-helpful previous post!
Posted : 23/07/2010 10:44 am
Just spoken to TFT and I think we're sorted on the problem now, and it is as you suggest.
Oil from the damper section (upper chamber) leaks into the lower leg. This causes hydraulic lock and you end up with hardly any travel. Glad to hear that it wasn't my servicing at fault! Seals need replacing, basically.
Posted : 23/07/2010 11:34 am
can buy the seals off LoCo who posted above
Posted : 23/07/2010 11:50 am
Yeah, I think LoCo is you man for seals, but remember it's only 2 standard O rings to fix it.... 50p worth! And there's plenty of places you can get them from!
Posted : 23/07/2010 11:53 am
thanks
loco ygm
Posted : 23/07/2010 12:08 pm
Sorry to hijack but I have the same problem with a Reba race and just after the cheapest way to get it sorted. The lockout still works but I only get 80mm travel (should be 100) is it just a case of replacing the o-rings or the seals as well?
Matt
Posted : 23/07/2010 12:36 pm
